Adding new Mailboxes
What Are You Trying to Do?
Is there a way to add more Mailboxes/folders? I would like to create more places to save messages other than just ‘Archive’.
What Have You Done So Far?
I tried the edit feature, but only seem to be able to hide default mailboxes/folders.
Am hoping the edit feature could include a way to Add another folder.
What Did You Expect to Happen?
Adding more mailboxes/folders will enable putting saved messages in different places to avoid having them all lumped into the ‘Archive’ mailbox/folder.
What Else Have You Tried?
I also looked in settings, but did not see an option there to add either.
Have You Checked Existing Help?
Yes — still stuck
What Did You Find?
No relevant matches for ‘new mailbox’, ‘new folder’, etc…
iPad
26.5.2
2.0.1 (2)
Direwolf
Thanks for the detailed write-up. You’re right: 2.0 has no way to add mailboxes. Edit only shows or hides the built-in ones.
Before deciding how to handle this, I’d like to understand how you’d use it. There are a few ways to organize mail (custom folders, tags, smart folders that fill themselves by rules, or one archive with good search), and the best fit depends on the workflow. Could you share some concrete examples?
  1. What folders would you create? Real names help (a net, an exercise or event, a contact, a form type, etc.).
  2. How would messages get there: filed by hand, or automatically by sender, subject, or form?
  3. Would a message ever belong in more than one place?
  4. When you go back to an old message, how do you find it: browse a folder, or search by sender, subject, or date?
  5. Roughly how many messages do you keep, and for how long?
If anyone else wants this, please add your own use case below. The more examples, the better.
Thanks for looking at this!
  1. I would create a folder for each major group or activity I participate in regularly. In my WinLink Express Application I have folders for: ARES, RACES, SDF, SHARES, TPRFN, Weather, Filed Day.
  2. I put them there by hand. All incoming messages are either deleted or moved to one of the folders.
  3. The subjects I use don’t overlap.
  4. I locate the old messages by looking at the folder. Rarely search as I can quickly spot what I am looking for. It would be nice to be able to also have a search ALL. (Some other mail systems have this feature and I do use that from time to time when I forget which folder the message may have been filed in).
  5. In general, I end up saving about 1-2 messages each week; more during an exercise. I have not yet deleted any.
