Icom IC-705 Access Point Connection
  1. With IC-705 in Station and iPhone connected to home WiFi, able to successfully Add Device and operate.
  2. With IC-705 in Station and connected to iPhone with iPhone as hotspot, able to Add Device and operate.
  3. With IC-705 in Access Point and iPhone connected to IC-705 WiFi, unable to Add Device.
  4. Tried multiple times ensuring password was typed correctly.
  1. Radio is found, but when you enter the Network User and Password, you get an error message “could not sign in to the ic-705. Connection failed: could not reach ic-705 at ic-705.local…”
Expected that Access Point would have worked like Station.
iPhone
26.6
2.0.2 (5)
IC-705
Screenshots
I just tried that exact scenario and the password validation worked fine. Are you sure you’re entering the correct username/password?
Yes. Same username and password as the Station mode. Note that Access Point does workuse when using Icom’s RS-BA1 remote software to connect a Windows laptop to the IC-705 for digital modes, so I know Access Point works on the 705.
The way I try to connect is:
  1. Set the IC-705 to Access Point and turn on WLAN
  2. Connect the iPhone to the IC-705 WiFi in the iPhone WiFi settings
  3. Run RadioMail App on iPhone
  4. Add Device
  5. Select the IC-705 when it is discovered
  6. Enter username (same one I use for RS-BA1 when doing digital with the laptop)
  7. Enter password
  8. Click Done
  9. After around ten seconds or so it says it can’t connect.
The only two thing different from Station mode is which WiFi the iPhone is connected to and which mode is selected in the IC-705 (and you can see the mode on the 705 screen with the opposite color WiFi symbol).
Just tried this, but using my iPad instead of iPhone and it worked.
so now a mystery of why…
Ok, figured it out. Why would it work with iPad but not iPhone? What was different?
The Cellular Data setting.
Had to turn OFF Cellular Data in the Settings, Cellular settings.
With it off it works, turn it on and it can’t find the IC-705.
See attached screenshots.
Mahalo
Steve
Interesting. It’s probably trying to route the request via cell data and fail. I would expect that if you put the phone in airplane mode it would work as well. Will have to figure out if there is a way around that.
Looks like I’m able bind the connection to LAN interface so that it will never try to use the cellular as a route to the radio.
Let me know when I can update the app and give it a try.
Mahalo,
Steve
