I am wondering if the Digirig VOX is only suitable for Lightning connections and I need the Lite or other method with iPad with USB C?
Digirig VOX cable is still labelled as “experimental”. Because it only uses passive circuitry, PTT activation can be hit or miss.
If you have USB-C available, the Digirig lite is a much better option.
Thank you. I will grab one. Now I have VOX, Mobile and will add the Lite.
Harley
KK7HMS
I did not have a PTT trigger issue, but the iPad would not produce adequate sound levels on both TX and RX. With the radio on full volume I did not get enough sound on the test to get into the green part of the bar (same radio works fine on older lighting connection and the VOX cable) and the iPad would not hold the output volume (speaker volume setting) when connected to the VOX cable. I would turn it up and then when I did test ping it would drift back down. Trying out the Digirig Lite.
