Setting up AIOC for RadioMail
New Topic
I got an AOIC to use with RadioMail, and it wasn’t working. The documentation is a little unclear on what you need to do:
AIOC requires firmware v1.4 or later with AutoPTT turned on.
After some research and experimentation, I figured it out:
  1. Plug your AIOC to your computer.
  2. Go to the web configurator in a supported browser (I used Chrome).
  3. Click CONNECT AIOC SETTINGS and pick the device that matches your AIOC (this may take a couple of times to figure out which one is right)
  4. Under TRANSMIT PTT SOURCES and PTT 1 Transmit Triggers, make sure at least VIRTUAL PTT is selected
  5. Click SAVE PERMANENTLY TO AIOC
Now try it in RadioMail. Note that if you ever mess up, just click RESTORE FACTORY DEFAULTS to start back from scratch.
