Unable to change station filter if no stations are listed
  1. Opened RadioMail
  2. Initiated a connect session (with the intention of using a VGC VR-N76)
  3. In the Station selection (Best Path Predtictions) prompt I added fiters for Modes: “Packet”
As there are no registered nearby stations supporting packet, the list is empty, and the UI to change the filter is not shown, making it impossible to change the filter back to also include “VARA FM” (or other modes), or add/remove bands from the filter.
To get back the filter selection UI, I unselected “Use Current Location” and changed “Current Grid Square” to a location with a known Packet station in the directory.
I expected the Filter UI to be shown also when there are no stations in the list, so that there is a way to change it.
iPhone
27.2
2.0.2 (5)
VGC VR-N76
Screenshots
Good catch for this edge case. Thanks for reporting. Will work on a fix.
