I have a question and I haven’t been able to find a way to do it. I live in an area where cell coverage isn’t all that great. I have to use my phone over wireless LAN to make and receive calls at times.
Under radio mail . one of my RMS gateways is on an extension of my home wired network. I would like to use my gateway directly instead of CMS from my phone.
I haven’t been able to figure out how to add a second telnet session.
Yes, you can use your own RMS gateway directly from your phone over Wi-Fi.
To set this up in RadioMail:
- Tap Stations > Add Station
- Enter your RMS gateway’s callsign
- Select TELNET for the Mode
- Enter your gateway’s host, port, and optional password
- Tap Done
The station will now appear in your favorites.
To use it:
- Tap the envelope icon to start a session
- Tap Favorites
- Go to the TELNET tab
- Select your station and tap Connect
The last selected station will become the default next time you connect.
To have RadioMail use your gateway for automatic background fetch:
- Go to Settings > Automatic Fetch
- Under Channel, choose the TELNET station you added
Thank you ,
I knew there had to be a way to do it. It works perfectly.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
