From RadioMail’s perspective, the BLE interfaces to the BTECH UV-PRO and the B.B. Link adapter are functionally identical. They both expose a KISS TNC.
The practical differences in your setup come from the packet TNC modem implementation (AFSK modulation, packet decoding, buffering, etc.), as well as the radio hardware and antenna.
Assuming features such as Roger beep and squelch tail elimination are disabled on the UV-PRO, any remaining variance might simply due to radio performance.
so far unable to get my uvpro to work with a Mac or my iPhone. I can’t get it to connect. I can have un paired it followed the instructions, forgot it in the blue tooth list. re added every other thing I can think of and no jow. any tricks?
When you say you cannot connect, I am assuming the iPhone is controlling the HT ok and you see the screen change to the Packet Frequency for the node you are trying to connect to?
What antenna are you using on the UVpro? I have found that some “Fancy” ones don’t seem to work at all, but the crappy rubber duck that came stock on the HT does work.
Also not sure where you are and where is the station you are trying to connect to and have you tried different stations? From my home here in Los Angeles there is only one packet radio station I can access N4XRO and it does not always work, not sure if it’s weather conditions or does he shut it down? If you have a strong connection, usually you will hear the BRAPS if you have the volume up.
I hope some of this helps.
I was having a similar issue with my thd75, turns out my local Winlink station has issues and is down. I then traveled to the next nearest stations location and it work flawlessly. I would try to get closer to the station before you try anything else. I got a smiley 2m super stick for when I need to reach out. Radiomail is the best Winlink client software
