Cannot get RadioMail to Find my UV Pro
I cannot get RadioMail to find my UV Pro. TNC is checked. Digital mode is unchecked. I paired it with the BHTech app then disconnected it so there wouldn’t be another connection. I shut off my PC so WinLink Express wouldn’t interfere. Telnet works fine. But when I try to connect to a packet station, I don’t see the radio start transmitting like it does with WinLink Express. And then either it says it can’t find the radio or the connection times out without any apparent transmitting from the radio. Any more ideas?
Does the radio appear in RadioMail (Settings > Packet KISS TNC Modem)? Are you able to select it? Has RadioMail been granted access to bluetooth?
Thank you so much for your suggestions! “UV-P” appears under Settings > Packet KISS TNC Modem > Default TNC. I checked Apps > RadioMail and Bluetooth was OFF, which is odd because I thought I had turned it on! Now it finds the radio :tada::tada:I’m still having trouble actually connecting to the local node, but at least RadioMail finds my HT. Good news is that someone from our local radio club volunteered to come over and help me troubleshoot, so I’m hoping to get on WinLink soon.
