Could not seem to add a comment with position report
Hello.
     I went to make a position report. I saw that I could add a comment as part of the report. “Publicly visible and limited to 148 characters”.
I attempted to select the field so that I could add a small comment. I could not seem to select the field to add the comment.
Using an iPhone for the app.
Thank you
Vince Grimaldi
KM6YHE
Press and hold the envelope icon. Should bring up three different items.
John Madden
N4EJM
DMR ID 3165878
Hamshack Hotline 6102039
I’m sorry the edit icon. Lower right. Oops.
John Madden
N4EJM
DMR ID 3165878
Ok disregard everything I just said. Looks like it’s not working. My bad.
John Madden
N4EJM
DMR ID 3165878
Hmm. Not obvious. A user should be able to touch anywhere in the field to edit the field.
The lower right did work
Vince Grimaldi
KM6YHE
I am talking about the comment field in the position report option
Vince Grimaldi
KM6YHE
Tap anywhere below the line »position report. Limited to 148 characters.«
Really, this does work quite well for me?
Without placeholder text in a text field, it's unclear where to tap to set the focus. iOS doesn't support placeholder text in multi-line fields directly, so a custom solution is needed. This is something I'll consider, as it has confused users before.
