I've created a custom ICS-213 form that is useful to the local Eugene EmComm group. I am unable to find enough documentation or example on YouTube to move forward. Is there any better documentation or "How_To"s that I am missing?
Custom specialized forms can be imported into RadioMail. Go to Settings > Forms > Import. From there you can import the zip file directly. Once imported, custom forms will appear in the Forms Library alongside the standard forms.
I am not sure what the contents of the zip file would contain. Is that documented anywhere?
Sorry, I mis-understood that you had created the form already. The zip typically contains the .txt form manifest and two .html files, one for compose and one for display.
Perhaps this helps: https://winlink.org/sites/default/files/RMSE_FORMS/create_templates.pdf ?
Otherwise, I'd recommend heading to the Winlink support group https://groups.google.com/g/winlink-programs-group
Alternatively, look at some of the custom forms already created. There are some good examples with GPS support, for example the Windshield survey from https://winlink.org/content/cert
