IC-705 stuck in transmit mode
On three occasions while making an ARDOP connection using the Bluetooth on the IC-705 with Radiomail 2.0.0 (45) after the connection with the gateway failed (timed out) the radio was left in transmit mode. There was no modulation, so little or no RF was being emitted. The red transmit light on the 705 stayed on until the radio hit the 3 minute time-out-timer.
Radio was stuck in transmit mode.
I expected the radio to stop transmitting and to return settings to the state they were in before making the connection.
iPhone
iOS 26.6 and 27.0
2.0.0 (45)
Icom IC-705 using bluetooth
I am experiencing a similar issue with Vara fm not unbinding from the radio and it sticking in transmit mode… with ardop the radio keeps dropping the WiFi somewhere between the handshake and receiving messages
