My devices:
iPhone 8+ on iOS 16.3.1
Mobilinkd TNC4 Rev B - Firmware 2.5.9 - and they sold me the cable to connect this to my HT.
Yaesu FT5D
Things that work:
I can use the iOS aprs.fi app to send position beacons and messages through the TNC4 using the FT5D. No problem. Of course, I don't really NEED this, because the FT5D already does this with its built-in stuff anyway (though the interface for writing APRS messages is HORRID).
I can connect to a Packet gateway 4 miles away. This is quick and snappy.
What doesn't work:
I can't send an email. It acts like it's STARTING to, but it ends on the following screen/log/console
;PR: ********
; N0DZQ-10 DE N0MQL (EN35ld)
FC EM GA2DMODFMQYW 222 205 0
69 (and it hangs here a minute or so, transmitting briefly every several seconds, but not progressing, then eventually...)
*** Error: Unexpected AX.25 protocol error, code e. (and I can't see the rest because there's no scrollbars on an iPhone screen for some unexplained reason)
I posted a pic of this on Mastodon, to a handful of dudes with whom I'm trying to sort this stuff out. One of them ordered the Mobilinkd almost the same day I did. Received it one USMail day before I did (Sat vs Mon).
Someone from Mobilinkd said this:
"set the frame size to 128 or 64. RadioMail has a bug where it can corrupt longer packets sent via Bluetooth LE."
I took that to mean
Radiomail
- Settings
- Packet KISS TNC Modem
- Max length
It was set to 255. I reduced it to 128 and retried.
Same response. Exact same Error message.
I reduced it to 64 and retried.
Is there any validity to what the Mobilinkd dude said? Does Radiomail have a bug with regard to BLE connections and packet-size/frame-size/bytes-per-packet/whatever-you-call-it?
Is there some OTHER setting I should be adjusting in Radiomail to improve the chances I could actually pass mail over the radio?
73 de n0mql
