User story
As a RadioMail user whose radio has a built-in KISS TNC (VR-N76, UV-PRO), I want to turn off RadioMail’s automatic frequency setting, so I can connect to a gateway using the split or offset frequencies I’ve set on the radio myself.
Background
When a session starts, RadioMail tunes the radio with the KISS hardware command Set Frequency (0xEA). That command only takes one frequency, so the radio ends up on simplex and any split you set on the radio is lost. VR-N76 and UV-PRO firmware 0.9.2 and later can use separate TX and RX frequencies in KISS mode. Right now RadioMail blocks that.
Acceptance criteria
- Each device’s settings have a toggle, “Set radio frequency automatically.” It’s on by default.
- When the toggle is on, nothing changes from today.
- When it’s off, RadioMail never sends Set Frequency (0xEA) or Restore Frequency (0xEB), before, during or after a session.
- When it’s off, everything else about the connection works as before (KISS data, PTT, other commands).
- When it’s off, the connect screen shows the MANUAL indicator instead of the AUTO to let the user know they have to set the frequency on the radio.
- The setting is saved per device and survives an app restart.
- The toggle appears only for devices that support the hardware frequency commands.
