Packet Commander not connecting to Kantronics
The latest version will no longer connect to any of our Kantronics KPC3+. I did work fine. This needs to be corrected fast. We have a number of these and rely on them. If you connect to one of them without a digipeater, it appears to work right, but it’s not quite right. It’s not getting or reading commands properly. If you add one digipeater in, you don’t get a connection at all on the app, but in monitoring it, it is connecting, but it’s not reading the data correctly. We are all using BTECH UV-PRO. Tested from Apple iPhone. This used to work fantastic.
Can you clarify, does Packet Commander never establish a connection to the KPC3+ or the connection is established, but commands/data are not being exchanged correctly after connecting?
Yes it’s connecting. The data is not being passed correctly.
