Now in the [AppStore](‎RadioMail on the App Store)
Check out the [release details](📶 RadioMail 1.4 - The “Audio Frequency Shift Happens” Release | RadioMail)
Hi,
I made the update - Both the BB-Link and RadioMail. When. I use my TH-D75 on KISS 1200Bd it runs flawless in 1200 Bd. When I switch to 9600 it skips the KISS mode on my radio. When 1200 Bd station with the 9600 Setting on my radio it switches correct to KISS 1200 and back afterwards. So it seems there is a problem on 9600 Bd setting.
73 de Erwin, OE1EKG
Erwin, could you give a step by step on how to reproduce the issue? For example:
1. Set radio to freq xyz, KISS 1200
2. Select station abc packet 9600 bps in RadioMail
3. Start connection in RadioMail
4. Describe what is happening on the radio
5. Describe what you expect to see on the radio
Hello,
Yes here is my setting and testing:
1. Set Data speed to 9600 on the radio
2. No KISS mode set on the radio
3. Enable BT on the Radio (TH-D75)
4. Start B.B.Link - connect correct to the radio
5. Start RadioMail and select a 9600 PR station
6. start connect.
Result
1. Frequency changes - wich is correct
2. KISS mode is disabled
Next without changes in between
1. Set Data Speed on 1200 on the radio
2. No KISS mode is st on the radio
3. Connect to a 1200 PR station
4. Radio changed frequency - wich is correct
5. KISS mode is enabled and switched to KISS12
So it looks like there is some problem with the 9600 setting?
73 de Erwin, OE1EKG
Erwin, I can't reproduce with the step you provided, the radio does go into KISS96 mode. Can you confirm you're running RadioMail 1.4.x and B.B. Link 0.7.8 firmware?
thanks for the fast reply. I use
- RadioMail 1.4.1 (7) updated yesterday from the AppStore
- B.B Link 0.7.8
I tried it again today like I wrote you in my message before.
I only tried it on one repeater with 9600. Wondering what the problem could be.
I made a third test now and before I deleted the Radio from B.B Link and reconnected it. Same behavior.
73 Erwin, OE1EKG
