Radiomail crashes when importing ZIP
  1. Click settings icon
  2. Click Forms
  3. Click Advanced Custom forms
  4. Click Import ZIP…
  5. Navigate to ZIP file and click it. ZIP file imports correctly to Winlink Express
    → crashes!
  6. Create a new ZIP file. Navigate to it and click it.
    → crashes!
Any suggestions?
Every time I try to input a ZIP file the program crashes.
Imported ZIP file should then allow me to use custom forms.
Mac
Goldengate 27.0.1
2.0.0 (45)
Internet
I can’t reproduce with some of the zips from https://winlink.org/content/cert
Can you post the zip you are using?
Also happens on iPhone with latest beta version of RadioMail.
iPhone 17
iOS 26.7.1
https://chathamauxcomm.org/forms-%26-documents
Zip file is there
Thanks. I am able to reproduce the crash.
Two of the reply-form manifests in Chat AUXC Winlink Forms v2.3.zip point back at themselves:
  • NC ICS-213 General Message Reply.txt has the line ReplyTemplate: NC ICS-213 General Message Reply.txt
  • NC ICS-213RR Resource Request Reply.txt has the line ReplyTemplate: NC ICS-213RR Resource Request Reply.txt
A ReplyTemplate: line tells the client which form to open when the recipient replies. It belongs in the initial form (e.g. NC ICS-213 General Message.txt, which already has it correctly). A reply form normally does not need a ReplyTemplate: line at all; when it names its own file, the client follows reply → reply → reply forever. If a reply-to-a-reply is not intended, remove the ReplyTemplate: line from those two .txt files. Winlink Express happens to tolerate this, so it was likely unnoticed.
A fix will be included in next release of RadioMail.
