RadioMail message editing
Is it possible to edit a RadioMail message already in the Outbox or in Draft before sending it?
Yes, you can edit a message in Drafts, but not in the Outbox.
Once a message is in the Outbox, it’s staged and ready to be sent—so it’s locked for editing. If you need to make changes, you’ll have to delete it from the Outbox and recreate the message.
To edit a draft:
  1. Open RadioMail.
  2. Tap the Drafts folder.
  3. Select the message you want to edit.
  4. It will open in the message composer.
  5. Make your changes, then tap Save to keep it as a draft, or Send to queue it for delivery.
