It would be useful if I could filter the stations list so I could 9600 baud packet stations, for example. right now I have to go to Winlink to find this.
This make sense. Will have to address filter interdependencies UX challenges, for example does not make sense to filter for 9600 if only filtering for Vara FM.
Mark, have you been successful connecting with Packet 9600? This is one use case I was not able to test with my local setup.
So far I have been unable to connect at 9600 either with RadioMail or Winlink. I am planning to try again after I adjust my antenna.
Now that I have saved some favorites, I notice that favorites saved on one device (iPhone) do not appear on another device (iPad). Both are logged in with the same callsign. I eould prefer that favorites be saved with the callsign.
To clarify, using RadioMail you're not really "logged in" anywhere much like you're not logged in when using an email client app (i'm not talking about browser based stuff). Your Winlink credentials are used to authenticate you against a server that requires them, which the default Winlink CMS does for example.
Why does this matter? RadioMail does not rely on a "server" to function. It does leverage certain API endpoint that Winlink provides to retrieve stations for the directory for example, but everything is cached locally. The idea is that the app should be functional without internet access.
So to go back to your suggestion, yes supporting multiple instances of RadioMail would be nice. That would include sharing favorites, user added stations, etc. and the most valuable part would be to have all the mailbox synced. This is something I'm considering, probably using iCloud for that purpose. This is on the roadmap https://trello.com/c/WyXr95q5
