Hi Georges et al,
Just got a Mobilinkd TNC4 and I’m trying to get it running under RadioMail.
Using the MobilinkdTNC app on my iPhone, I connect over Bluetooth just fine. I can transmit a test tone, no problem. (Though, a tip - be sure to tune to a different frequency than your local club’s 2m repeater when testing this feature… ![]()
But, when I’m in RadioMail and go into Settings, I select Packet KISS TNC Modem, and the TNC4 does not get auto discovered.
Is there a setting I should set in the config app so that it will be auto discovered? Should I disconnect in the app? I’m sure I’m doing something wrong, but I’m not sure what it is.
Thanks!
Cheers,
Ken van Wyk
Armata Scientia
