Using Mobilinkd 3. Cannot cannot fully to a known good station. And ideas on this error message?
Code J means there is a sequence error. Possibly means a frame was received with an unexpected number. Could be due to poor decoding of incoming frame, possibly due to level not adjusted properly.
* Make radio squlech is fully open.
* Make sure radio audio levels are setup properly. Go to the mobilinkd app and adjust audio gain and twist levels.
Thank you. I did both when that was happening, but I was in a hurry. I will slow down and try again to see what happens.
