UV-5RV2 Mobilkind Packet Winlink
I have a UV-5V2 that works with AOC and Windows to same packet Winlink.
Now trying to connect to the same station with Mobilkind and UV-5R using Mac Radiomail. It PTT the HT but never connects and fails.
Same Mac connects and was able to connect using UV5 Pro HT
I am pretty sure I have the settings OK on the Mobilkind such as audio levels using IOS app. And squelch at 1 and Dual watch off and radio on correct frequency.
No connection, but same setup works using UV/PRO
Should connect and send and retrieve win mail
Mac
26.6.2
26.6.2
UV5R and Mobilkind 4
Squelsh should be fully open. The other setting that is going to be radio specific for the mobilinkd is its twist compensation. Last, have another radio monitor. If you hear the RMS answer back, it’s most likely a volume, twist, etc. essentially audio path into mobilinkd. If you don’t hear a response its most likely a RF/antenna problem.
Thanks so much for the speedy response.
I am not sure what I did, I fiddled with the audio settings in the Mobilkind app and now it’s making contact and sending mail.
The new version of RadioMail is really nice, great work and thanks for such a great product.
