Varanny using Beelink Mini S12
Aloha Everyone-
So, I purchased the Beeline Mini S12 PC. I got it setup and installed Winlink Express and VARA FM. I’m able to successfully run VARA FM via Winlink express. However, when I ran Varanny, I can set the audio fine on RadioMail but when I run a session there is no PTT and it disconnects immediately. VARA window on Beelink does open but no PTT.
Interesting enough, I’m able to run Varanny on my Dell laptop windows 11 and Surface Pro Windows 10 just fine.
Any ideas would be appreciated.
Mahalo 73 Ron AJ7GS
Can you post your varanny.json file?
Hello-
Cut and paste my varanny.json file. I have a THD75
“Port”: 8273,
“Modems” : [
“Name”: “THD75”,
“Type”: “fm”,
“Cmd”: “C:\VARA FM\VARAFM.exe”,
“Config”: “C:\VARA FM\VARAFM.thd75.ini”,
“Port”: 8300
Ok so presumably the VARAFM.thd75.ini should have the correct AUDIOCARD and PTT section that VARA FM expect. What soundcard are you using and how do you expect to drive PTT (VOX or COM port)?
I’m using same DigiRig Lite soundcard. No Comport. Using RA-Board as setup in VARA. Similar to same setup you have on the video. My question is why would Varanny work on my Dell laptop and Surface pro? Using same soundcard. VARAFM.THD75.INI are similar…. No problems with PTT…
One way to ensure you have the right settings is to open VARA FM and verify all the configuration is correct and that you can make a connection (perhaps using Winlink Express).
Then close VARA FM and copy the VARAFM.ini as VARAFM.THD75.ini.
Hello-
As I had mentioned I can successfully execute Winlink Express via VARA FM on my Beelink Mini PC with either VOX or RA-Board PTT setting. Not sure if this helps but I was able to run RadioMail with manual Modem setting on my IP address and port 8300 on my Dell laptop. Tried the same setup but with a different IP address on Beelink Mini PC and still no success…
So that should take varanny out of the equation. Are you sure the VARA ports are open o the Beelink?
It should be considering I can run Winlink Exoress via VARA FM just fine…
Are you running Winlink Express on the Beeline or from another computer?
I can run Winlink Express via VARA FM on Beelink Mini PC…
The other computers were Dell and Surface Pro. Success using Varanny, entering the IP address via RadioMail and Winlink Express via VARA FM with no problems…
When you run Winlink Express on the Beelink, it connects via localhost. It does not guarantee that the port is open so you can connect from another computer. I would look into that first.
Interesting. Where would I check?
